- Need Help!- Acramatic 2100
Re: Acramatic 2100
Alex, This Control has two PC-Motherboards with BIOS (Basic Input Output Settings)
WSCPU(Work-Station Left) & RTCPU(Real-Time Right) Each has a barcode label on the bottom inside lip of the
aluminium Board Frame 3-424-xxxxAyy. The Work-Station BIOS Setting can be put into the board only if you have
a separate PS/2 Keyboard hooked up to the WSCPU. Settings are in the Control Reference Manual.
The RTCPU Board was normally set on a bench with a power-supply; keyboard; video adapter; and a Floppy
Disk Binary file to flash the BIOS. Some users may have the settings recorded on paper and there are a few
who can set the setting for someone if the board is sent to them. Fives-MSI U.S. Tech support may be of assistance.
- You may not post replies
- You may not edit your posts
Forum Rules
