I'm still trying!
I don't have the original TL file!
I download from manul BDS5
Engine on the machine 1-604-0001
55A 230v 6000rpm
compensation module 275/2604?-010
Could this cause err18
I'm still trying!
55A 230v 6000rpm
ERR 18 BAD 'TL'
The BDS5 has two boards: a small MC board and a larger IBD board. Both
boards have the current and voltage rating encoded and they must match. If
this error occurs because you exchanged the MC card, then you should
replace the original card. If it occurs for some other reason, contact the
factory. This error breaks program execution.
Your Drive needs to be serviced by someone who does this for a living.
Fives-MSI (Cincinnati-Parts sells the 91203230 SaberHeidenhain-426CR (1996-97) prints (https://store.fivesmsi.com/)
Everything was repaired by VFS5!
And the PSR4 / 5 power supply was repaired.
The machine works!
Thanks to the forum and to AMERICAN FRIENDS!
KHARKOV
UKRAINE
