g-code
Results 1 to 3 of 3
Thread: g-code
    Member cncmakers001's Avatar
    Jul 2011
    China
    Default Re: g-code
    Quote Originally Posted by jarl85 View Post
    hi all
    how will the gcode by to go home in ACRAMATIC A2100?
    thanks
    G00 or G28
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Mar 2008
    Default Re: g-code
    You can set a HOME position with the Pendant and use the G28 with P variables. RAP will explain this.
    I prefer to move the Machine Axes to where I want the Home to be; then select "Current Display" screen.
    Record the desired "Machine Position" Coordinates.
    You can program a M26 ; This moves the Face of the Spindle to a full Z-Retract position in Machine Coordinates.
    Program a G0/G1 G98.1 Xx.xxxx Yy.yyyy Fxxx ;to position the X & Y in Machines Coordinates.
    This will NOT be lost at a power fail or unsequenced shutdown; like the HOME position.
g-code
g-code
