Kollmorgan drive and kitagawa rotary table
Results 1 to 4 of 4
Thread: Kollmorgan drive and kitagawa rotary table
    Jun 2008
    Default Kollmorgan drive and kitagawa rotary table
    I have an Cincinnati Arrow. Years ago I bought a Kitagawa rotary off EBay, rotary model TB160 as I recall. The rotary has its own control box. However the machine is pre-wired for another drive.
    If possible I would like to control the 4th rotary from the machine control.
    Will a kollmorgan drive run this kitagawa rotary or is there more to this that I need to know and do.
    Mar 2008
    Default Re: Kollmorgan drive and kitagawa rotary table
    Sarms,
    You would need a Kollmorgen Motor with amps to match the Drive.
    You do not say if it was a Kollmorgen BDS4 Drive, or a Kollmorgen Servo-Star. The motors are quite different.
    Jun 2008
    Quote Originally Posted by gwood View Post
    Sarms,
    It's a BDS4 drive.
    Mar 2008
    Sarms, A BDS4 Drive has a sticker with a Model Type
    i.e. Drive Type: BDS4-206-23-412W32 (A-axis 6-Amp) Motor Type : A axis 1-604-0210
    Member mike_Kilroy's Avatar
    Sep 2010
    There is a small chance the BDS4 can run your motor; list your motor part number - and specs if you have them - and we can tell you if it can work.
    Mike@@@KilroyWasHere.com
