System Variables list for acramatic A2100
Results 1 to 11 of 11
Thread: System Variables list for acramatic A2100
    Feb 2014
    Default System Variables list for acramatic A2100
    hello all
    do somebody have a System Variables list for acramatic A2100
    thanks
    Karl
    Mar 2011
    Default Re: System Variables list for acramatic A2100
    Variables for the A2100 are dependent on several items such as the machine manufacturer (i.e. Cincinnati, Tree, Mighty, etc.), type (VMC, HMC, TC) and Model (Arrow, Sabre, Lancer, Hawk, Avenger). It was also used as a retrofit control on many different types of machines which each had custom MAI's written for them. There were too many variations to just randomly guess as to what you are looking for.
    Member machinehop5's Avatar
    Aug 2009
    Quote Originally Posted by jarl85 View Post
    hello all
    thanks
    Karl
    ...no---knot...yet
    sos
    Feb 2014
    cincinnati arrow 750 1997 year
    Mar 2011
    I also forgot to mention software version affects it too. I have a list from a 97 Arrow which is likely very close to what you are looking for, but it is hundreds of pages of raw data that does not seem like it would help you. What specifically are you looking for/trying to do?
    Feb 2014
    hi Maver1ck
    can you maybe send me the list?
    thanks Karl
  7. #7
    Mar 2008
    Jarl85, I agree with maver1ck; if we do not understand what you are attempting to do we cannot help you. The permutations of trying to guess what you need are futile.
  8. #8
    Feb 2014
    ok
    I'm looking to activate air solenoid for the spindle,
    thanks, Karl
  9. #9
    Mar 2011
    I have only seen a limited number of these machines with an Air Blast through the spindle (tied into the through spindle coolant system).
    Is this what you're asking about? or are you referring to the solenoid for the drawbar cylinder? or are you trying to add an aftermarket air purge to the spindle?
  10. #10
    Feb 2014
    hi
    yes I'm talking about Air Blast through the spindle
    thanks Karl
  11. #11
    Sep 2008
    MExico
    These machines do not have many air valves, you should be able to physically find it and activate it manually.
