- Need Help!- Acramatic 850 SX Cincinnati Lathe
I having trouble to on the control acramatic 850 SX
Display SYSTEM START-UP HOST CONTROL INITIALIZING
Couldn't on the Hydraulic. any help please
Re: Acramatic 850 SX Cincinnati Lathe
your battery might be dead...
Look inside the back electrical panel, you have a silver box with a board in the left that has lights and 4 switches on it. Write down the light colors and the switch names. If you have the control reference manual it has a section on trouble shooting using the lights. Do you have 2 green lights at the bottom of the lights for the power supplies. Make sure the switches are to the left.
MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
- You may not post replies
- You may not edit your posts
Forum Rules
