- A2100 CONTROL HELP
A2100 CONTROL HELP
Hi all,
I have a falcon lathe with an A2100 control that had been working fine
up till now. The machine sat for a few months and now I get a blank
screen when I push the start button. - nothing- I remember having this problem with
other machines we had in the past and it was usually a simple fix.
Anyone know where to start ?
thanks
Jim
Re: A2100 CONTROL HELP
Look at the power supply in the A2100 control box, is the fan running, do you have 220 vac at the black plug, is the green light on inside the small open window on the left bottom of the control box. Do you have power in the mag panel?
MIKECNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
CRT or LCD screen? I have had to replace a lot of backlights over the past few years.
Be careful throwing the power off without at least trying to shut it down. If it is the backlight, the control is still loading and killing power during the software load can corrupt your hard drive (givimg you 2 things to fix.
Also possible a dead battery on the WS board. There were a few of the boards that couldnt boot up it the CMOS battery died.
As Mav said, you might run into problems with the hard drive turning on a off. I would disconnect the hard drive to eliminate any chance of corrupting it.
- You may not post replies
- You may not edit your posts
Forum Rules
