- Need Help!- Cincinnati arrow 750 CT
Good Morning to all, my cincinnat milacron arrow 750 (controle technique FNC5) no longer performs the boot (black screen) but all drives and cards are powered, can someone help me? Thanks to all
Re: Cincinnati arrow 750 CT
It sounds like the battery for the memory is dead. You need to replace the battery and re-install the memory and all the parameters. You should contact FIVES Machine Company 800-934-0735 and talk to Greg Wood. Cincinnati Milacron did not use the CT control for very long and support is limited.
MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
- You may not post replies
- You may not edit your posts
Forum Rules
