- Need Help!- Cincinnati Arrow WMC-500 - RT BOARD BIOS
RT-Board : PN : 3-424-2379A02
BIOS : Award v 4.51pg (ROM PCI/ISA BIOS (2A5LED42))
Battery lost because the machine stay stop too long and since we have this error there : APC RACK 0 (Output Fuse Failure)
We have checked the 24v and everything is correct
We made the following configuration in the BIOS :
- Standard CMOS setup:
* the primary master/slave and secondary master/slave must be = NONE
* The drive A and B must be NONE
* Hald on= All but Keyboard
- Bios features setup:
* virus warning disabled
* cpu internal cache enabled
* external cahe enabled
* quick power on self test! enabled
* boot sequence A C SCSI
* swap floppy drive disabled
* boot up floppy seek disabled
* boot up numlock status on
* memory ecc function disabled
* type matic rate settings disabled
* typematic rate chars sec 6
* type matic delay 250
* security option setup
* pci/vga palette snoop disabled
* os select for dram non OS2
* hdd smart capability disabled
* video bios shadow disabled
* C***** disabled (2 lines)
* D***** disabled (4lines)
- Chipset features setup
* dimm 1... Normal
* dimm 2... normal
* sdram ... 3
* video bios cacheable enabled
* system bios cacheable disabled
* memory hole... disabled
* cpu to pci... enabled
* pci dynamic... enabled
* pci master.... enabled
* pci delay... enabled
* pci master .... enabled
- Power management setup
* power management disabled
* pm control.... yes
* video off methos DPMS
* video off... suspend
* stand by mode disabled
* suspend mode disabled
* hdd power on disabled
* resume ... disabled
* from IRQ3 to IRQ7 = Primary
* IRQ8 disabled
* from IRQ9 to IRQ 12 secondary
* IRQ13 primary
* IRQ14 primary
* IRQ15 disabled
- PNP/PCI configuration
* Resources control... Manual
* Reset ... diabled
* IRQ3 and IRQ4 = PCI/ISA PNP
* From IRQ5 to 10= Legacy ISA
* IRQ11 PCI/ISA PNP
* From IRQ12 to IRQ15 LEGACY ISA
* DMA0,1 and 3= PCI/ISA PNP
* DMA5 and DMA6 Legacy...
* DMA7 PCI/ISA PNP
* Pci Irq... Level
* assisgn... disabled
* PCI SLOT1 and 2 = Auto
Integrated Peripherals
* Onboard primary... disabled
* Onboard Secondary diabled
* IDE pref... enabled
* IDE HDD... enabled
* Onboard FCC.. disabled
* Onboard UART 1 = 3E8/IRQ4
* Onboard UART 2 = 2E8/IRQ3
* Onboard Uart2 mode: standard
* onboard parall... disabled
Thank you
Re: Cincinnati Arrow WMC-500 - RT BOARD BIOS
When I have seen this error (APC RACK 0 (Output Fuse Failure) it is because the battery on the RT board which is on the far right, has gone bad. This board has the BIOS on it and is maintained by the battery. What you have described is the settings for the BIOS which is on the WS RT board which is the WORK STATION board on the far left. Did this correct your problem, and did you check the battery on the RT board on the right?
MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
We have all checked, the battery is new, is it possible to have the BIOS binary file of the RT-BOARD 22399.cms
- You may not post replies
- You may not edit your posts
Forum Rules
