Search for "spider insert". Those are common replacement parts, you just have to determine the correct size. Measure the diameter and look for any markings.
Some time ago I had one of those failed in a vacuum pump. I CNC'd a temporary replacement out of PVC foam. Worked perfectly fine for a month until the real part arrived.
