Cincinnati arrow drive problem
Results 1 to 4 of 4
Thread: Cincinnati arrow drive problem
    Nov 2016
    Portugal
    Default Cincinnati arrow drive problem
    Hello,
    I'm having the problem on the video below.
    The machine had a lote of problems after reaching this situation.
    MikedeckArt repaired the computer( now it's ok) then i repaired the psr and now i'm having the problem with the y axis.
    The X,z work perfect the y work ok If i put the X drive.
    The drive in the y axis was a bds4 6 amps But was not ok the i replace for this one removes from another machine i have But it is a 10amp and when i move the jog it moves like the movie .
    Could it be only a adjustment problem or could this drive be bad. ? The motor on both machines are the same.
    Hope someone could help me. I'm trying to repair this machine since about 1 year and this is the only thing is missing to put ir to work.
    Nov 2016
    Portugal
    Could not upload the video i Will try to compressor it.
    What the video shows is that when joging the y axis it jumls and release the alarm excessivo folowing error. And doesn't move again. If i switch y drive for the X the y moves ok and the problem goes to the X.
    Could be need to adjust since the drive i put have 10amps instead of 6?
    Member machinehop5's Avatar
    Aug 2009
    Default Re: Cincinnati arrow drive problem
    ....assuming all your Cables, Plugs, and wiring to Y motor/feedback loop are ok ...could try adjusting the Stability Pot a little bit on the Y axis BDS4 amp. (It's at the very top)
    https://www.kollmorgen.com/en-us/dev...lation-manual/
    Cincinnati arrow drive problem-bds4-amp-jpg
    DJ
    Nov 2016
    Portugal
    I all the cables are ok, because i switch drives with the x and it work ok with other drive. But this drive i think should be ok because it came from the other machine, and it was working. The diference is the current rating.
    I don't understand very well what those pot change. but i will try do adjust the stability a little to see if anything changes.
    Quote Originally Posted by machinehop5 View Post
    DJ
