Need Help! acramatic 2100e Hawk 150 MDI position wrong but program position correct???
Results 1 to 2 of 2
Thread: acramatic 2100e Hawk 150 MDI position wrong but program position correct???
    Member fettersp's Avatar
    Jan 2020
    Default acramatic 2100e Hawk 150 MDI position wrong but program position correct???
    I have a hawk 150 that has been idle for a month now. my father passed away and I inheriated his machine shop. I usually run the kia lathe but need to learn to set up the hawk.
    My father has a step by step set up guide for it but my issue is in mdi. When I tell the machine to go to X1.533 it will go way below the part instead of right above it and I don't know why. If the machine is in program mode and I tell it to go to X1.533 it will go right above the part?????? I'm trying to set the z zero but I'm unable to until I figure out why MDI mode is acting this way?
    The code he uses for it is
    T11 M6
    M2
    G92 S3000
    G0 X1.533
    G1 G96 G95 X -032 S500 F.006 M13
    G0 X1.533
    M0
    G92.1 Z0
    The instructions will say when to run each part of the program to set z zero.
    Mar 2008
    Default Re: acramatic 2100e Hawk 150 MDI position wrong but program position correct???
    FetterSP,
    If you run this code in MDI does it work properly?
    :G90G70
    ; There really should be a line here to move the turret to a clear indexing position
    T11 M6; Index to and activate tool #11
    G92 S3000; Set a MAX Rpm of 3000 in CSS mode
    G0 X1.533
    G1 G96 G95 X -.032 S500 F.006 M13 ;Invoke CSS & FPR... Problem --- You were missing the Decimal Point in "X"
    G0 X1.533
    M2; End of Program - Data Reset and Rewind
