4th axis locks and unlocks after every line of code
Results 1 to 7 of 7
Thread: 4th axis locks and unlocks after every line of code
    Oct 2011
    Default 4th axis locks and unlocks after every line of code
    As the title says, my newly acquired 4th axis locks and unlocks after every line of code. Are these things able to do full 4 axis machining, or are they just 3+1? My machine was already 4th axis ready, so it was plug and play.
    Attached Thumbnails Attached Thumbnails 4th axis locks and unlocks after every line of code-20200504_145534-jpg
    Mar 2008
    Default Re: 4th axis locks and unlocks after every line of code
    coop31, Machine Type, Control Type would be needed info. Are you running in "Single Block" or "MDI"? The Control Software loaded is on the 'MORE>> ' > 'Service' page if a A2100 Control. Options turned on are on the 'MORE>> ' > 'SYS Configuration' > 'Purchased Options'. A2100 UK-VMC was always a contouring full 4 axis.
    See Attached File: A21-16 VMC Rotary Axis.pdf
    Attached Files Attached Files
    Oct 2011
    Quote Originally Posted by gwood View Post
    Thanks for the reply.
    Machine is arrow 750 A2100 control.
    I've written a few lines of code in MDI and have also wrote a small program. Single block not on.
    On the small screen that showes what's modal, as soon as I command any movement the screen shows m10,even though I programed m11 in the previous line.
    Is it possible I have to program some type of g code to specify contouring?
    Mar 2008
    If properly configured in the 'MORE >>' 'SYS-Configuration' > 'Machine Application' the Rotary Axis should be firing an air solenoid to unclamp; then looking for the M11 Unclamp Switch feedback.
    GregW
    Call Fives-Canada for support: 905-673-5201
    Mar 2005
    there should be a code to release the brake for full fourth work, at least there is on a Haas. M10, engage the brake, M11 brake off.
    Oct 2011
    GregW
    Thanks Greg, I called and they are going to look into it for me.
  7. #7
    Oct 2011
    Quote Originally Posted by 2COOL585 View Post
    Yes, exactly the same code for the Cincinnati arrow with a2100 control.
    Problem is that the control is locking and unlocking between every movement if there is a A axis move. Stays unlocked if I only move x y Z.
