Need Help! Cincinnati 20VC Acramatic 850 Manual Request
Results 1 to 2 of 2
Thread: Cincinnati 20VC Acramatic 850 Manual Request
    Member sbtn94's Avatar
    May 2020
    Default Cincinnati 20VC Acramatic 850 Manual Request
    Hello,
    I got a Cincinnati 20VC with Acramatic 850.
    I need maintenance manual to find this error I got. (See attached photos)
    Error Codes:
    SPDL Speed Fail 22 CR
    Alert Number: 17380
    If someone can help me find what this error are.
    Thank you.
    Attached Thumbnails Attached Thumbnails Cincinnati 20VC Acramatic 850 Manual Request-47d28021-c463-4ec4-849e-b9136f1ddeda-jpg   Cincinnati 20VC Acramatic 850 Manual Request-ad62f8e1-a52a-4600-aa2c-fb00913c33d1-jpg
    Mar 2008
    Default Re: Cincinnati 20VC Acramatic 850 Manual Request
    The control puts out a DC voltage command to the spindle drive; typically +/- 9.98DCV at Max Spindle RPM in the low or high gear and 1/2 that for 50% speed etc...
    Hopefully the spindle turns quietly and freely so there is no mechanical bind.
    Check the incoming phases line to line for the proper voltage.
    you can check the velocity command output to the drive; if it is what you expect you can check the current output on each of the 3-legs to see if they are equal.
    there are spindle drive adjustments to check. If those are correct then you should disconnect and Ohm each leg to the other leg and Mega-Ohm the motor.
    Bill Oehler at Fives-MSI (Cincinnati) used to support that product; 1-800-934-0735 Listen carefully for the prompts for Cincinnati & Tech Support.
    Best Wishes GW
