Cincinnati Hawk 150
Results 1 to 7 of 7
Thread: Cincinnati Hawk 150
    Jun 2007
    Smile Cincinnati Hawk 150
    I am starting to work with a cincinnati Hawk 150. This is a used machine and we don't have all the manuals for it. I was wondering if anyone could help me locate manuals for this machine. I will also need help with the renishaw tool setter. Just wondering what tool offset page a person uses for tool setup,and for working offsets. This machine has an Acramatic A2100 controller.Can a person use the g code canned cycles for threading ,rough turning and boring like on the fanuc controllers? How does one set up for tool change positions? I have run this controller on a Cincinnati Arrow 750 Machining center but not on the turning centers. Any help will be greatly appreciated. I have been away from the trade for a few years so I'll need some help refreshing my memory. Thanks
    Mar 2008
    Smile Cincinnati Machinetool Support
    For FREE Cincinnati Technical support you can call 1-800-934-0735
    Listen to the prompt for Cincinnat; then for Tech support/Parts.
    or... #4 wait for the ring to answer then #2 for Tech support/Parts.
    Greetings from: Tech Support MAG Global Services
    Jun 2007
    Quote Originally Posted by gwood View Post
    Thanks for the info gwood. Looks like I will be the new owner of this machine in the new year. I have been running this machine part time for the last 3 years. It should have a few more good years of production left in it. Is there any way to tell how many hours this machine would have?
    Thanks Again
    Mike
    Mar 2008
    Call in with the serial # off the back of the machine and we can tell you when the machine was ordered. There was never an hour meter in any of the Acramatic controls.
    Member mrafitraders's Avatar
    Oct 2014
    Lahore
    Hi, I recently import Concinnati hawk 200 Cnc lathe with fanuc 21it Control from uk. Machine had a issue of sram data. I put the data and machine is ready now. The only problem with the x axis, when i run the x axis, the reading is changing on the crt screen but mechanically doesnt move. Anyone help me in this regard? Thanks in advance.
    Attached Thumbnails Attached Thumbnails Cincinnati Hawk 150-img-20180507-wa0011-jpg
    Mar 2011
    Most obvious thing to check is whether motor is turning as commanded and if coupling is broken/missing. If the machine doesn't have scale feedback, it doesn't know if the axis is moving, only if the motor is.
  7. #7
    May 2016
    United Kingdom
    Default Re: Cincinnati Hawk 150
    Probably the coupling
Cincinnati Hawk 150
Cincinnati Hawk 150
