- Need Help!- Acramatic 2100 on a Cincinnati CNC. Spindle Motor won't start
On Startup, machine goes to Home position but Spindle motor will not complete itself to have machine ready to run. Does anyone have an electrical schematic for this machine or suggestions for fixing this problem? Thanks.
Re: Acramatic 2100 on a Cincinnati CNC. Spindle Motor won't start
Does the spindle turn but it can't find the home position? Did you change any parameters in the control or the spindle drive? Do you have the black colored Kollmorgan spindle drive or something else (servo star ) ? Do you have an error code on the control or the spindle drive, if so what does it say??
MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
- You may not post replies
- You may not edit your posts
Forum Rules
