Arrow 500 spindle motor upgrade
Results 1 to 4 of 4
Thread: Arrow 500 spindle motor upgrade
    Jun 2007
    Default Arrow 500 spindle motor upgrade
    The spindle motor in my Arrow 500 started making noise.
    It sounds like the lower bearing is going bad.
    Is it possible to swap the original 8k rpm motor with a 12k rpm motor.
    1998 Arrow 500
    Model ERO
    S/N 7042-A0B-98-1704
    A2100 control
    Kollmorgan Goldline motors
    Jun 2007
    Default Re: Arrow 500 spindle motor upgrade
    Edit: original motor is 10k rpm, machine has 8k rpm spindle.
    Mar 2011
    Quote Originally Posted by Don18P View Post
    In theory it should be possible, but that doesn't mean you should. Any spindle over 8000 rpm on these machines was accompanied by a spindle chiller to keep the spindle from overheating (and I believe it was limited to 10K on that vintage). Putting a higher speed motor may have you replacing your spindle sooner than you'd like if you don't take proper steps to accommodate this.
    I am actually parting out a 98 Arrow 500 ERO right now, so probably have the motor you would need if it becomes necessary to replace it, but barring any major issues with the motor, yours should be able to be repaired as well.
    Jun 2007
    Thanks maver1ck.
    I'm not looking to gain more spindle rpm, just exploring motor options.
    I can't afford the downtime to rebuild the motor.
    Did find a few 10k motors available in Grand Rapids Michigan
    Will swap motors then rebuild the original.
