Hi Ihab, glad to see you were using the forum.
Martin Josse
Hi guys please
I have a Cincinati CNC machine ARROW 500, i have a problem with realtime cpu board part number is 3-424-2168A02 and error is NC Engine base failed.
And i replaced the battery and i need the bios programming file and set up for the bios
Any help would be greatly appreciated
Many thanks
Ihab abass
- A2100 Realtime board BIOS help request
- Need Help!- Acramatic 2100 Realtime CPU Board BIOS
- Need Help!- Acramatic 2100 Realtime CPU Board BIOS 2a5led42
- Need Help!- acramatic 2100 bios help??
Martin Josse
Ihab Abass
Fives-MSI Cincinnati can Re-Flash the BIOS using a Floppy Disk Program; we then Test it in a Simulator with a CMHD I/O Board Tester, DV5 and Pendant.
Call us 800-934-0475 Cincinnati&Repair Prompts; or Direct at 859-534-4750 ask for repair, or Technical Support.
Greg
