- Multi setup question
I run a multi set up Cincinnati in the aerospace field I have a couple of questions #1 How do I set up the sequence to run the setups in a sequence? #2 When I'm doing an m-19 the spindle becomes fixed and S that gives coordinates for the spindle orientation. We keep having to take our right angle head apart and adjust it is there a way to offset the "s" to alter the spindle orientation?
Re: Multi setup question
M19 Sxxx should orient to whatever angle (xxx) you want.
- You may not post replies
- You may not edit your posts
Forum Rules
