- Acramatic 950 Cycles
I have a question regarding drilling cycles on my Maxim 630 with an Acramatic 950 CNC.
We have a deep hole we need to peck drill. I wanted to take a large initial peck and then a reduced amount for each additional peck. Is this possible in the cycles or would it need to be written out long hand?
Thanks.
Look in your programming manual at G83. Using a K word sets a variable depth per peck. I believe it only has 3 stages though (3xK for first peck, 2xK for 2nd peck and 1xK for all additional.
A J Word can also be used for chip breaking (J0) or chip clearing (J1) in the cycle.
Re: Acramatic 950 Cycles
You are correct, there are only 3 stages. I found the data. Again, thanks.
- You may not post replies
- You may not edit your posts
Forum Rules
