- S.O.S. SABRE 750 - ACRAMATIC 2100 (year 96)
Hello dear friends,
Anyone willing to lend a hand here, we are going through a crisis here where there is absolutely no tech support, we are located in South America. Our machine is a 1996 Cincinnati Milatron SABRE 750 with control ACRAMATIC 2100. and the system configuration parameters got mixed up.
We are in desperate need of a set of parameters (backup archive) if some of you have a same type machine, we will greatly appreciate it. Many thanks in advance!
Peloflex.
Re: S.O.S. SABRE 750 - ACRAMATIC 2100 (year 96)
I cannot help you as I dont have your machine. However. In your other post I responded with someone who should be able to help you. Good luck.
Thanks a lot brother! God bless you!
Get on our web site to send me a email and I will send you what I have.
Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
ZanderGahel 02:51 AM Hoy
Tengo un problema con un control Sabre 750 A2100 al que se cambió el codificador del husillo que controla la orientación ahora cuando la referencia genera la siguiente alarma 44-6 Falla de alineación de cuadrícula del eje C que creo que se debe a que el husillo no está orientado quería saber cuál es la forma de recalibrar el encoder y la orientación del husillo de antemano gracias.
- You may not post replies
- You may not edit your posts
Forum Rules
