- Need Help!- Sabre 750 tool change problem
Hi guys.
My machine won't do a proper tool change. It puts away a tool in the drum, z goes up, and alarms out. It doesn't rotate the drum while at spindle
I found a way to run the machine all day, I put T0 M6 before tool change, so it puts tools in the drum, drum parks, rotates to next tool, drum then moves to spindle, z goes down and program continue.
Any suggestions much appreciated
Tom
Sent from my D5803 using Tapatalk
Re: Sabre 750 tool change problem
This is the alarm when I try to rotate the drum while it's by the spindle
Case solved.
3 phase cable going to a drum motor broke on 1 bend. Just by pneumatic cylinder.
Hope it helps someone on future.
- You may not post replies
- You may not edit your posts
Forum Rules
