Arrow 2 1250C Realtime Timeout
Results 1 to 4 of 4
Thread: Arrow 2 1250C Realtime Timeout
    Aug 2015
    Default Arrow 2 1250C Realtime Timeout
    Okay. So I read a lot of these posts in this forum to learn from everyone else and the issue that they have. However, with all that info, these machine are still quite complex and confusing. My machine is getting to a point where I am going to have to start addressing all the issue. One of which is Z axis bearings which will be another post possibly, but I think I can manage. But the one I cannot is the Work Station Board and the Real Time Board issues. Randomly I get alarms for Realtime Timeout and with it it normally stops running the machine. I shut it down, then boot it back up and cross my fingers I get another few days to weeks out of it before it happens again. Today however, I got this alarm again. Although this time the machine is continuing to run as normal, with the exception that the screen is not showing any movement in the axis' or the program is not moving forward. I am currently letting it run with optional stop on for now and will restart after this tool is over. But my question is, what causes this? Batteries in the WS or RT board getting low? Bad connections on the bridge board between the two? A bad RT board? How can I help narrow this down? I am thinking of pulling the computer out of the cabinet and replacing both batteries on the boards. Then afterwards maybe un plug and re plug every board/connection to make sure it has a good solid connection. Could this maybe solve these issues? It doesnt happen very often, so if it were a low battery Id feel as if itd happen more frequently, I could be wrong though. Any input on where to start would be great. I did add a heat exchanger to the door of the cabinet to help keep the cabinet a bit cooler as I know heat really kills electronics.
    Attached Thumbnails Attached Thumbnails Arrow 2 1250C Realtime Timeout-20190904_085500-jpg
    Dec 2006
    Default Re: Arrow 2 1250C Realtime Timeout
    The boards have a watch battery that doesn't last forever, it's only a matter of time. If you try to replace the 2 batteries you will lose everything. You can pull out the boards and check the battery voltage but do not remove the battery!!!!!! A new battery is about 3.3 VDC. We have an adapter that puts a new battery in parallel with the old battery then the old battery can be replaced then adapter can be removed, works great. Where are you located?
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Aug 2015
    I do know the batteries dont last forever. I also know to NOT remove the batteries without the boards being powered. However, can low or dead batteries cause the issues that I am seeing? Or is this a different issue? As for replacing the batteries, can I dissemble the entire computer out of the case and reassemble outside the case on a work bench and be able to access the RT battery? I replaced the WS battery sometime ago and I remember that being the easier one to replace of the 2, but dont remember if you could access the RT battery at all if the computer was built outside the case and propped on a bench? If this is sitll not possible then I will have to look into those adapters for changing the battery. I am located in Rochester NY
    Oct 2011
    Quote Originally Posted by JordanMach View Post
    I've had similar problems in the past. Try replacing the computer power supply.
