error
Results 1 to 3 of 3
Thread: error
    Mar 2011
    Means the axis was out of position, either moved further than expected (i.e. runaway axis) or didn't move as far as expected (i.e. motor power cable is disconnected).
    These are the two extremes, yours is likely somewhere in the middle but without detailed information, can't be specific. There are many potential causes for either.
    Dec 2006
    Default Re: error
    With the machine off you need to remove the left hand X axis way cover and look at the motor electrical connections and turn the ballscrew to make sure it turns easy
    It help if you gave us more info on the problem along with the type of machine and drives. Do you have scales??
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
error
error
