- Need Help!- Cincinnati Hawk 150 CNC Lathe
*Registered User*
I Have Cincinnati Hawk 150 CNC Lathe i buy for it new hard disk with software after old one damage but i get attached alarm when do align for axe and turret and spindle
if you have same machine model can send me photo for setting pages
Re: Cincinnati Hawk 150 CNC Lathe
Not sure about the turret, but I've seen spindle alarm like that. Check the kollmorgen power supply if it's green light comes on, also spindle drive all green lights on.
Does turret lift at all, does it rotate ?
Do axis go home?
Sent from my D5803 using Tapatalk
*Registered User*
turret and spindle not rotate
yes axe go home
Make a video of the back of machine and ask someone to home the lathe. I suspect kollmorgen drive fault.
I have the same machine. Which pages you're interested in?
*Registered User*
need photo for all page in
system config -servo
system config - axis data
i think data in new hard is not for hawk 150
video i makefor you tomorrow
- You may not post replies
- You may not edit your posts
Forum Rules
