- air
air
hi
i have cincinnati 750 with A2100 control
is there a m code to activate air blast in spindle?
thanks Karl
Re: air
The air blast is part of the tool change cycle and is not programmable that I know of. If you have the option of M70 codes you could re-wire it up to work.
MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
Re: air
- air
- You may not post replies
- You may not edit your posts
Forum Rules
