- Need Help!- Acramatic 2100 Realtime CPU Board BIOS 2a5led42
Activation process
Tengo una cnc arrow 1000
tengo cnc cincinatty arrw 2100 el cual presento error de rt
se le cambiaron filtros a la board
se le coloca otra board y la maquina trabaja bien
mi pregunta es?
alguien tiene la configuracion de bios de esta board rt
es una board g7vp2 con bios 2a5led42
daba error de rt y error de servo, estos ya fueron solucionados
hay posibilidades que sea la bios o la configuracion de la misma que este bloqueando la bridge (rack 0)
gracias
Re: Acramatic 2100 Realtime CPU Board BIOS 2a5led42
ENGLISH ENGLISH ENGLISH !!!!!
Paquiro,
The RT-CPU board on the right side has a "3-424-xxxxAyy" part number on the Barcode Label on the lower inside lip of the metal board chassis.
You cannot change the battery on this board unless the board is on a bench under power without losing the BIOS Settings.
The Bios on these boards is Flashed in using a Floppy disk with a binary parameter file. Fives-MSI Cincinnati charges $350 USD to
Replace the battery; Flash the BIOS Parameters; Test the board in a Simulator with a special I/O Tester Board Assy.
It normally takes 1-2 days once we receive to board to do this.
The WS-CPU board on the left side has a "3-424-xxxxAyy" part number on the Barcode Label on the lower inside lip of the metal board chassis.
The Bios on the WS-CPU board can be re-entered with a PC style keyboard. The settings are in the Control Reference Manual or we can email them to you.
Our Tech Support Phone number is 01-859-534-4750 8am to 5pm EST (Lunch Noon-1PM EST) No hablo Español
Greg Wood Fives-MSI "Cincinnati" Hebron, Kentucky USA
paquiro 99 If you need support in Spanish, I can help you ... contact me
- You may not post replies
- You may not edit your posts
Forum Rules
