Cincinnati Sabre 1000 HH 415 ERROR when start pump
Results 1 to 3 of 3
Thread: Cincinnati Sabre 1000 HH 415 ERROR when start pump
    Member witbike's Avatar
    Jun 2015
    Poland
    Default Cincinnati Sabre 1000 HH 415 ERROR when start pump
    Hello guys,
    I have a problem with my machine. When program (spindle, axis and water pump) started or turn off, machine sometimes showing a Gross positioning error... Sometimes when spindle rotate and I hand turn on pump is the same problem. I know what mean Gross positionig error, but now it is not relate with loose in machine. It look like the voltage dropped... I change contactor from pump and nothing better. I do not know where I should looking problem.
    Dec 2006
    Default Re: Cincinnati Sabre 1000 HH 415 ERROR when start pump
    WHAT IS YOUR INCOMING VOLTAGE, Are you running this machine on a phase converter or industrial 3 phase? It sounds like it is related to a voltage drop. What control and drives do you have on this machine?
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Jun 2015
    Poland
    It is HH 415 BR. Drives FANUC. Sometimes, but very rarely on PCB show LV LED. Machine is connect to 3phase. I have 3 other machine which working fine.
