- cincinnati milacron arrow 500 acramatic a2100e
Good companions, I use English translator, we have sold this machine and the 4 axis has been disassembled because we were not interested, the control gave an error because I could not find the A axis encoder (4th axis), I have disconnected it from the control and now the error that appears to me is 44-43, the control tells me that I must make a plug to make a loop, I do not have an electrical diagram of this machine, you can help me, the servos are BSD4.Thank you.
Re: cincinnati milacron arrow 500 acramatic a2100e
On the pendent you can to select to REMOVE the A axis but you may need a loop back connector to jumper things like MOTOR OVERTEMP and the motor resolver feedback. YOU NEED TO GET THE ELECTRICAL PRINTS FOR YOUR MACHINE!!!!
MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
Thanks for your answer the diagram I need is the 91202971
I believe all loop back plugs are the same. Email me and I will remember to send you how to make one. Mike@kilroywashere.com
Sent from my SM-G900V using Tapatalk
- You may not post replies
- You may not edit your posts
Forum Rules
