Ok, drive is working properly but I still have an issue that I cannot pass though.
In defining the spindle speed drive range, we are able to set the gear ratio - Input gear teeth in the menu below.
so that we achieve the desired speed when the analog input voltage is 10VDC. This works ok with the setting 8400 as long we do not disconnect the power from the drive.
However when the disconnect the drive power, the value goes back to 4096, and the input value does not stay persistent. Other values do not require a "SAVE" or similar and stay persistent.
Any ideias about what should be done to keep the 8400 value saved?
Can this be related to some input on the drive that we are not considering? I reviewed the documentation but found nothing relevant.
