- Problem- Rigid tapping not authorised G84.1
Re: Rigid tapping not authorised G84.1
I think all you need is to have the special code. I dont think you need to add any hardware. I may be wrong, but my machine I bought used came with Rigid Tap enabled and I dont see any special hardware that would have been installed for this.
The dart is a basic machine/control, you need to contact Mike Trunk at FIVES 800-934-0735 to get a code. You should press MORE then CONFIG then PURCHASED OPTIONS to see what you have.
MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
Hello!
Thank you very much for the answer, on Tuesday I will be in my workshop, I will check what option I have and then I will contact Mike. I know that I have a service level in the machine, so it should be a bit easier.
Best regards,
Adrian
- You may not post replies
- You may not edit your posts
Forum Rules
