- Need Help!- Issues with the COM and Startup diagnostics Acramatic 2100
Hello,
I just brought used Cincinnati Arrow 500 with Acramatic 2100 but have the following issues:
1. When I try to get in CNC Communications Setup to make the settings I get "Error in Get Facility =3B0004". However I have access in the menu but when I change something (bitrate ect.) and try to save I get "Error in Save Device Data =3D0001" and it wouldn't save.
2. Also on startup diagnostics workstation processor and high density I/O fail anytime .
What can I do to fix these?
Any help will be appreciated.
Re: Issues with the COM and Startup diagnostics Acramatic 2100
You may have a bad battery on the work station board and you may have lost the BIOS settings. Looks like you have more problems then communications . The 2 boards should not show a fault, check the RTC board battery but don't remove it.
MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
Thank you for the reply. I think the power supply may be out (today I noticed that the fan is not rotating).
First I should replace it and then will write what is happening. What do you mean by checking the battery without removing it. How can I check it?
You can check it with a volt meter, when it is new it should be about 3.3 VDC. You can check it on the board DO NOT REMOVE IT FROM THE BOARD ! ! !
hi dear
do you have ws board bios setting ?
my board is: AA 670917-310
please guide me .
tanks
my email : amir.mmhb@gmail.com
- You may not post replies
- You may not edit your posts
Forum Rules
