- Arrow 1000 - “Application startup timeout. The exe name is CNC.EXE
Upon boot up, while loading “Loading Machine mode (3 of 13)” it hangs for a minute or so then gives the following errors:
“Application startup timeout. The exe name is CNC.EXE”
Then
“CNC overflow”
All diagnostics pass, no fault lights from what I can see. Can reference the machine but as soon as you click to enter machine mode or try to run a program it locks up.
This machine is already using a CF card for a hard drive.
The machine was running fine at the end of the day yesterday. Any ideas?
Re: Arrow 1000 - “Application startup timeout. The exe name is CNC.EXE
Ended up being something corrupt on the drive. I put in the backup CF card and everything works as normal.
- You may not post replies
- You may not edit your posts
Forum Rules
