Need Help! A2100 gcode
Results 1 to 2 of 2
Thread: A2100 gcode
    Oct 2016
    Default A2100 gcode
    I just bought an arrow 500 and I’m just trying to figure out this control. I went to run a test program that was a dynamic tool path and it had incremental ijk in it. The control gave me an end of arc out of tolerance. I changed the outputs to radius and it worked fine. Is this control capabile of inc. ijk or do I stick to radius.
    Dec 2006
    Default Re: A2100 gcode
    The control looks for a true circle within 0.001" when using IJK in a G02 or G03. You can open the window press MORE, CONFIG, PROGRAMMING, and at the top bar I think it is under circular and open the value in the box.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
A2100 gcode
A2100 gcode
