- Problem- Cincinnati sabre 1000 - TNC 415 - 29 3 axis drive overload
Re: Cincinnati sabre 1000 - TNC 415 - 29 3 axis drive overload
Hi from Norway.
I have similar machine and I have lost my software!
Could I have a copy of your software??? Please!!! NC25993712. PLC27828105.
On Hedenhain homepage you find "TNCremo" With this software you take a backup of machine software.
I recommend you to do so (If you have not done it)
And the battery that power the storage of machine software must never be change with main power off.
Best regards Morten
I cannot help you much, as I dont have that machine. I have an Arrow 2 1250C with A2100 Control. I can help with your pressure gauge though. That should only show pressure when it is in a lubrication cycle. It does not lube every second. Depending on the machine they are set up to lube every so many minutes(I have seen an average of 20 minutes). When it does do a lube cycle, you will se the pressure go up, but only for a brief second. It send a few drops of oil to each lube point, which happens very very quickly. If I am not mistaken, I think if you press that red button, it will force a lube cycle. Dont quote me, I do not have that exact lube system. Although from all lube systems I have ever seen, there is a button to force a lube cycle. If that button does force a lube cycle, you will then see that pressure gauge rise quickly then fall quickly. I hope this helps you a little bit? As for the rest, I cannot help. MSNK is correct though, only change battery with power to boards(although I dont see you asked that, good for future reference though).
Hi
I need parameters same your machine,
Cincinnati milacron Sabre 1000 with TNC 415
00966507104945
- You may not post replies
- You may not edit your posts
Forum Rules
