Arrow 500 Spindle Lube Fault - where is the lube?
Results 1 to 11 of 11
Thread: Arrow 500 Spindle Lube Fault - where is the lube?
    Dec 2005
    us
    Default Arrow 500 Spindle Lube Fault - where is the lube?
    We are in the process of getting our arrow 500 up and running and now we got a spindle lube alarm. Where is the lube? Is it the air/lube on the back of the machine? This is a '95 machine.
    Feb 2009
    Default Re: Arrow 500 Spindle Lube Fault - where is the lube?
    Yes air oil system. I believe those have a prox switch that monitors the oil drop.
    Mactec would know the best.
    Dec 2006
    The spindle uses a air/lube system that is monitored by a box in the outside of the back of the machine under a cover. It looks at several inputs from pressure switches and has a timed cycle. You should see some lights on this box with faults next to the lights. What do the lights show??? Post a pic of the lube unit and the lights to make sure we are talking about the same thing. Where are you located???
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Dec 2005
    us
    Arrow 500 Spindle Lube Fault - where is the lube?-oiler2-jpg
    I did not find any kind of a lube control with LED indicators.
    Dec 2006
    It looks like you don't have a spindle lube unit on your machine. It only came with a high speed spindle, You have a standard speed spindle. What you have is the standard air filter, regulator, lubricator unit. Did you install new software or something??
    Dec 2005
    us
    Yes, we installed a new hard drive and have gone through the M1Y files that we got from FIVES but maybe one of the values is wrong. Any suggestions?
  7. #7
    Dec 2006
    If you received your M1Y*** file from FIVES it is a generic file that is not setup for your machine. You don't have the options that the file is looking for. You need to go through your settings and set them up for your machine. Do you have any old documentation from your old parameter settings??? Where are you located???
  8. #8
    Dec 2005
    us
    I do not have any documentation from our old parameter settings. We are located in LaGrange Oh 44050.
  9. #9
    Mar 2011
    Quote Originally Posted by meckardt55 View Post
    Mike - I know you are trying to help people, but giving incorrect information just confuses the issue. To clarify, all Arrows after a specific vintage (about the time A2100 came out) had the air/oil mist lubrication system on them, not just the high-speed spindles as you indicated. Some of the earlier Arrows (Joe's machine included) still used the old spindle with greased bearings instead of the air/oil system.
    The high-speed spindles you referred to (10,000 RPM and above) also had a chiller to cycle fluid to the spindle cartridge that was not included with the lower speed spindles.
    I helped them configure their new hard drive, and Fives did provide a machine specific file for them, not a generic one as you indicated. The issue was that it was created on a much earlier software version, so importing it into the new hard drive had compatibility issues.
  10. #10
    Dec 2006
    I stand corrected. Thanks for your input.
    Mike http://cncmachine services.com
  11. #11
    Sep 2009
    India
    Hi Guys,
    I have a Cincinnati Lamb CFV1050 with a Siemens 810 D controller, for which I'm having a similar issue. The machine is showing the "Alarm 700007: Spindle Lube pump failure", within 2 seconds or so of pressing the data reset button/ powering on the machine.
    The machine axes can move, but I cant run any program thanks to this alarm.
    The machine does not have a separate Lubrication pump, but has an oil mist unit for the spindle. This is done by a pneumatic solenoid and two small plunger type assemblies for creating an oil mist dispersion.
    It has the 2 CKD PPD3 digital pressure switches, and the output from these appear OK (Not tested the voltages, but pressure readings and Output ON OFF seems OK as per the pressure settings). Even when we override the switches to be in ON, the spindle Lube alarm pops up again.
    The pipelines to the spindle from the oil mist unit are also OK and checked, no leakages there.
    Any suggestions on how to handle this? I have the electrical circuit diagram, but the pneumatics on this machine are controller through a Profibus DP (Rexroth) Pneumatic controller. I don't have any other machine manuals or logic diagrams to help solve this issue.
    Does anyone know the settings for the CKD PPD3 unit? (it has 4 output type options, but when you try to configure it you cannot see what the original settings were)
    Thanks and best regards
    Jaideep Shinh
