- Need Help!- Hawk 150 Machine Power Up Issue After Changing Cmos - A2100 Control
Hawk 150
A2100 Control
1. Machine would not turn on - blank screen with a 1"x1" square in the center of the screen.
2. Changed cmos battery, reset time and date and checked cmos setup parameters.
3. Machine boots fine but is missing keyboard/touch screen. We have a mouse and keyboard hooked up to get past the touch screen not working.
4. Here is the problem, besides the touch screen not working everything seems fine, when I go to power the machine On by pressing the green button nothing happens. I have tried checking the I/o board but it is not reading the slot/rack numbers.
Is there away to power on the machine other than pushing the green button?
Re: Hawk 150 Machine Power Up Issue After Changing Cmos - A2100 Control
Also there are no alarms on the screen. Everything seems fine except for the touch screen and buttons not working. Before the cmos battery died the touch screen worked.
Why did you change the 2032 battery on the WORKSTATION board (far left) ??? Did you also change the 2032 battery on the REAL TIME BOARD (far right)??? How do you know the BIOS (cmos) settings are the same???
Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
Hi dear.
I have a Cincinnati Milling Machine. With Acramatic 2100 control. I had a bios battery message. And the clock was constantly erased. I changed the battery on the ws board. Unfortunately, I have ws fail alarms. And does not work.
This ws board model is: aa 670917-310
Do you have bios settings?
please guide me .
my email : amir.mmhb@gmail.com
Thanx
- You may not post replies
- You may not edit your posts
Forum Rules
