Acramatic 850SX
Results 1 to 7 of 7
Thread: Acramatic 850SX
    Aug 2009
    Default Acramatic 850SX
    Hello,
    If anyone is interested in turning on options in the 850SX, here is some info.
    There may be a different way to do it but I come from a hardware background so I dig into hardware instead of software.
    I read the eeproms on the memory card and have located the option bits, reprogrammed and reinstalled the eeprom (in a socket) and it all works fine.
    I will not post too much in case no one cares!
    These controls are old and all but impossible to get support from the maker. Otherwise I would suggest going through proper channels for option upgrades.
    Nov 2007
    What's the chance you could do the same on an Acramatic 950MC? I believe the 850 is actually newer than a 950 if that's any help.
    Jay
    Dec 2010
    Parts and repair is available on some of the Acramatic control series from Siemens who owns the product. Siemens can be contacted at 800-879-8079. It is true what peterson76 says in that these controls are old and access to components to repair is limited. If the iron is still good, a retrofit is an option which Siemens can help with. When calling the 800# the customer support reps can forward your information to someone to follow up on discussing the retrofit options.
    Sent from my iPad using Tapatalk
    Sep 2006
    Hi, im very interested in what your doing i need some upgrades on my 850sx its on a horizontal mill how can i get ahold of you or you can email me at:
    miran86@exede.net
    Jul 2009
    turkey
    Hi
    I am having trouble for turning the cincinnati Acramatic 850sx control panel.
    my motor drive is siemens.
    SUMP off
    DIMP off
    GMEM red
    DAMP red
    RUN yellow
    OSA red
    MMC red
    SERV off
    PCA red
    DPWR green
    APWR green
    Display SYSTEM START-UP HOST CONTROL INITIALIZING
    then there is no movement. waiting for help for this problem. thank you.Attachment 433443Attachment 433445
    Default Re: Acramatic 850SX
    This is a super old thread but if this is possible who knows how to do it and can you explain a little more detail? Thanks
  7. #7
    Dec 2006
    You need to get the control reference manual that shows how to trouble shoot using the lights.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
  8. #8
    Member machinehop5's Avatar
    Aug 2009
    Quote Originally Posted by VENDETTAD View Post
    ...supermachines. rebuild it better
  9. #9
    Quote Originally Posted by peterson76 View Post
    Hello,
    IS THIS GUY STILL AROUND? ANYBODY KNOW? ID LIKE TO KNOW
Acramatic 850SX
Acramatic 850SX
