Vickers 2100 won't boot, scrambled screen
Results 1 to 7 of 7
Thread: Vickers 2100 won't boot, scrambled screen
    Jul 2013
    Default Vickers 2100 won't boot, scrambled screen
    My vickers 2100 control is acting up. Replaced CMOS batteries and re-entered parameters in the BIOS.
    After the blue Windows NT screen I get this on the screen then nothing. Any ideas?
    Attached Thumbnails Attached Thumbnails Vickers 2100 won't boot, scrambled screen-image-jpg
    Mar 2011
    This is what happens to a specific vintage WS board when the WS battery goes dead. If you re-entered the settings, you didn't get them correct. I suppose it is also possible that your board is bad, but the chances of that happening exactly when you change the battery seems pretty slim unless it was damaged when you were removing or installing it.
    Since you mentioned changing the "batteries", you more than likely also lost the RT settings as well, so once your WS board is set up properly, your machine still will not run until your RT board is re-flashed.
    I received your PM, but haven't had time to respond, and will need additional information. You may be able to configure the WS board yourself, but if you need help with the RT board, you will have to send it to me. I will respond to your PM when I get a chance with the additional information needed.
    Oct 2009
    It looking like I'm having the same problem here. I haven't removed the battery at this time. My bios version is 1.00.13.CV2 . Any help would be greatly appreciated.
    Thank you
    Shaun
    Mar 2011
    More than likely just the battery died. That BIOS version was used on several different boards, send me a PM with the board part number (it is in the format 3-424-xxxx) and I'll see what I can do.
    Member Gonshop's Avatar
    May 2019
    Default Re: Vickers 2100 won't boot, scrambled screen
    Hi, I'm new here, I have the same problem, that image appears on my screen,
    I bought the equipment and it came with a fault , someone could help me thanks
    May 2019
    Quote Originally Posted by Macman45 View Post
    Hello, you have solved your problem??
    - - - Updated - - -
    Quote Originally Posted by maver1ck View Post
    Where can I contact you?
  7. #7
    Mar 2011
    The quote you posted says how to contact me.....Send a PM. Depending on which board you have (and your ability level), this could be a simple fix, or it could require you to send the board out for repair.
