A2100 Realtime fail
Results 1 to 6 of 6
Thread: A2100 Realtime fail
    Feb 2011
    Default A2100 Realtime fail
    This control is only a year old give or take a month or two. Diagnostics claims the realtime processor has failed on startup but when you look at the leds on the BBB
    there are not any red leds to indicate failure. Has anyone heard of this one?
    Thanks in advance for your help.
    Scott
    Mar 2011
    Have you checked the batteries on your WS and RT boards? I have seen a large number of A2100 controls from the mid to late 90's with dead batteries in the last year, so it is worth looking at on your machine.
    If you decide to test the batteries, do not remove the batteries while checking them. If the batteries are still good and you remove them from the board, this will cause the BIOS to reset and you will have multiple issues to fix.
    Feb 2011
    Default doesnt make sense
    I changed out my X axis servo and I nolonger get any errors.
    How is this possible?
    Member mike_Kilroy's Avatar
    Sep 2010
    good gosh!
    what made you change out a drive for THAT fault? divine intervention??? WOW!
    You are amazing Scott!
    Mike@@@KilroyWasHere.com
    Feb 2011
    Mike I think you are correct. BTW I do have a couple Goldlines to send you pretty soon. I got another one about to go down.
    Take care,
    Scott
    Default Re: A2100 Realtime fail
    Hi Mav. Can you call message me your phone number? I need your help. Thx
A2100 Realtime fail
A2100 Realtime fail
