Originally Posted by
gwood
Alarm: run-off patches are set on.
press MORE>>
press SYSTEM CONFIGURATION
press SECURITY (top left)
type in CIMTROLUSA; Press ENTER; Password level changes to RUNOFF; then commit changes.
press MACHINE APPLICATION ( just above middle left hand side )
use the right arrow to move TABS until you see a tab labelled RUNOFF.
None of the boxes should have a tick in them. if there is remove the tick. commit the changes and that should be it.
Set the security level to SERVICE. In Security type SERVICE; Press Enter; Password Level = SERVICE; Commit Changes
Go to More>> SERVICE > Backup & Restore Machine Data: Defaults to 'Backup' > 'Machine Data' > Press Start Backup.
Repeat this step again, and add an "a:/" in front of the filename below to make a copy for safe keeping on a floppy; or Network, or RS232 (Worth it's weight in GOLD!)
Go back to MORE>>
type in operator; Press ENTER; Password level changes to operator; then commit changes. You are finished.
Now people can look; but not change parameters.
