Cnc auto tool calibration
Results 1 to 3 of 3
Thread: Cnc auto tool calibration
    Member Pauliusnagys12's Avatar
    Apr 2020
    Default Cnc auto tool calibration
    Helo
    I have been working with my cnc omi sytec 6mb for a while and everything was ok.but now when it want to mesure the tool on the tool measurement tip My milling machine just goes up ant stops becouse it reaches maximum z axis.So maby someone had a similiar problem when insted of going down to measurre the tool my machine goes up?
    Attached Thumbnails Attached Thumbnails Cnc auto tool calibration-7862ee70-f893-489e-a160-3be6126a64e4-jpg
    Member jason-weihong's Avatar
    Mar 2020
    Default Re: Cnc auto tool calibration
    you need to change your calibrator's polarity. I guess your calibrator's signal is on, that's why when you press measure and machine goes up.
    Mar 2020
    Quote Originally Posted by jason-weihong View Post
    Also, you can check your IO board, the calibrator's signal is on. as long as system got this signal, machine goes up.
    Hope this could sovle your problem.
    If sovled, please support WEIHONG controller next time you buy a machine.
