Excitech CNC - Syntec Controller Users - Page 24
Page 24 of 24 FirstFirst ... 1421222324
Results 277 to 287 of 287
Thread: Excitech CNC - Syntec Controller Users
  1. #277
    Apr 2014
    Default Re: Excitech CNC - Syntec Controller Users
    Quote Originally Posted by hadi2217 View Post
    hi
    thanks . finally i find them and set....
    Please can you share the knowledge with us? I have the same problem as yours... I have 1mm of the axis for every 1 meter of machine travel in x and y directions.
  2. #278
    Nov 2009
    uk
    Hi All,
    I have just bought a second hand Chinese router with a syntec ez3 controll.
    Everything is working well tool change etc and i even managed to connect it to the network.
    The problem i am having is the z homing.
    It homes to 1 of 2 different places each time the machine is switched on.
    1 homing sequence is z goes up, sensor light comes on, z goes down, light off, z goes back up, light comes on and stays on, system is homed.
    2nd sequence is z goes up, sensor light comes on, z goes down, light off, z only goes up only a few millimeters, light doesnt come on, system is homed.
    As you can see this means the machine z0 changes depending on where it homes to, this causes a big problem when going for a tool change.
    Any help would be appreciated.
    John
  3. #279
    Registered Keithconde's Avatar
    Aug 2016
    Philippines
    Excitech SHMS 2040C (SYNTECH EZ4M)
    Hi Everyone,
    I followed all your Post Thread and I gives some Ideas on how to troubleshoot our Machine..
    I would to ask for Help & Expertise regarding our Problem because It is hard to contact EXCITECH tehnicians.
    Our problem is regarding C-axis(Y2) because it does not HOME precisely in zero position not like the (Y1) in HOME Correctly,
    But somehow the machine can still run the smoothly, On the other we cannot HOME the machine in every End of the operation it should be
    on the far side of the HOME POSITION.
    Lately it disturb me during Engraving Machining if i repeat the operation because of low DEPTH it make a step cutting.
    Please Help.
    Respectfully,
    Keith
  4. #280
    Oct 2017
    Iran, Islamic Republic Of
    Quote Originally Posted by priestwood View Post
    my excitec shms1325 arrived since december and up till now it refused to work upon all the useful postings on the forum- i am almost fraustrated. i get the following error messages:
    1).When I did M6TX in MDI mode, I got the following error messages “ motion 17 z axis positive software limit exceed” and also “coordinate 40 the 1 NC program L1 block end point exceed software limit”.
    2). When I try to run my gcodes, I got the following error messages “ motion 18 z axis negative software limit exceed” and also “ coordinate 40 the 1 NC program L 11 block end point exceed software limit
    Also I noticed that when I move the router head towards the tool bank, as soon as the head passes the cutting limit and move towards the the tool bank, I get this error message, “motion 17 c axis positive software limit exceed.
    i will be very grateful if anybody can help me out, believe me it is fraustrating. i have been in tontact with excitec and they cant help i believe its partly because of language barrier.
    priestwood
    dear sir !
    i am using a chinese CNC with syntec 6mD controller.the machine was working properly and today when i wanted to run a G code ,it came up with this error :
    Motion 17 ZAxis Positive software limit exceed
    Coordinate 40 The 1NcProgramL1: exceed software limit or hardware limit
    however i tried to execute the other G code which i ran on the machine the day before,but still the alarm was showing up.
    i was wondering if it was the same as ur problem.i would like to know if u have solved it and what was the method to overcome this problem.
    my machine is 1325 with 7.5 kw HSD spindle.none ATC .
    ill appreciate if u can help me in this case .
    tx
  5. #281
    Sep 2004
    I had something like this as well, and it turned out the program I was running was, for reasons I cant remember, asking the z axis to exceed its limits. I think I checked my code and reduced the clearance for rapids above the work.
    Good luck!
  6. #282
    Jan 2018
    Hey everyone. Syntec has been working on a branch in the United States located in California, and it has began operation. I am the engineer there. I was looking through this thread and I see a few issues that sound like hardware or machine maker defects, but it also seems a lot of people have problems with controller alarms/usage. For anything controller related I can definitely help. If you guys have any questions that you have not yet figured out please post it and I will start checking this thread daily. If you are having controller issues that require more attention, documentation, or are more urgent please do not hesitate to email me at milan.ardeshna@syntecclub.com.tw
    Note: Dont forget the tw in the end of the email. You can also PM me on here!
  7. #283
    Jan 2018
    Hi ordibeheshd. The alarm is triggered when somewhere in the code it wants the machine to move past the limits set on the machine by the machine maker
    If you ran that G code before and it worked maybe there is a shift on your G54 location (or whatever other start point you entered)? Also if that was set properly could you have entered an external shift by mistake in the offset/setting page? Look through the code and check where the alarm triggers and how high it wants the Z axis to move. Please let me know what you find.
  8. #284
    Sep 2004
    Hi SystecEngineer!
    Great to hear there will be more support over on this side of the puddle, and I know I'm double posting, but I saw this and wondered if you know anything about this alarm;
    (R44.4) Double Driving master-slave excessive error alarm ?
    Its from a Systec 6MD.
    It doesn't seem to trip anything and programs go through it to completion, but I find it showing up in the alarm history. Sometimes I also get a lost pulse on the Y-axis.
    Thanks!
  9. #285
    Aug 2016
    Philippines
    Quote Originally Posted by routerhead View Post
    Good luck!
    Hi ,
    I truly agree on what he said..
    Check your Machine capability what i mean is LOADABLE working MACHINING & Lastly check your Programming..
  10. #286
    Feb 2018
    Viet Nam
    Can you give me infomations about the syntec keyboard in this picture and the address that I can buy it. thanks you very much
  11. #287
    Feb 2018
    Viet Nam
    Can you gime me all picture to my email: tunglamtnut93@gmail.com or give me informatons about the syntec keyboard and the address that i can buy it. thanks you very much
