Need Help! syntec ez3 parametres or manual
Results 1 to 3 of 3
Thread: syntec ez3 parametres or manual
    Member Klemo4's Avatar
    Jan 2021
    Default syntec ez3 parametres or manual
    Hi. I am trying to fix a cnc that has the syntec ez3 controller. For some reason it not getting in the correct position for auto tool pick and tool sensor. I already have broke one tool holder. Does anyone know where to set the positions? I have try to find the manual but no luck. Thanks
    Member elephantcnc's Avatar
    Nov 2011
    shandong
    Default Re: syntec ez3 parametres or manual
    Hi, friend. Hope this can help you.
    To adjust the tool pick-up and sensor positions on the Syntec EZ3 controller, you’ll need to access the machine’s parameter settings or reference the specific setup manual. Here’s a general guide:
    Access Machine Parameters:
    Enter the machine’s parameter settings by navigating to the system menu. Usually, this involves a password-protected admin area.
    Check the "ATC Settings" or "Tool Change Settings" menu.
    Locate Position Settings:
    Look for parameters that define the tool pick-up coordinates (X, Y, Z). These may be labeled as Tool Change Points or similar terms.
    Calibrate Manually:
    Jog the machine manually to the correct position for both tool pick-up and tool sensor touch-off.
    Record the exact coordinates.
    Update Parameters:
    Input these coordinates into the controller’s settings.
    Save the changes and test the movements slowly.
    Check Homing and Offsets:
    Ensure the machine is homed correctly before running tool changes.
    Verify offsets like G54, G55, or any custom offsets that might interfere with the tool path.
    https://www.elephant-cnc.com/
    Whatsapp/mobile: +86-15064026772
    E-mail: manager@elephant-cnc.com Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
    Jan 2021
    tnx for the reply man. i have see videos how is done but the problem is i do not know the parameters settings. i have see a video for 6A controller. Are the parameters the same for all syntec machines? i have find a manual "Syntec CNC Parameter Manual" does this work for my controller?
