Did some more measuring and the gear is 29mm OD with 20 teeth which gives me a MOD of 1.3181 and then when I measured the teeth of the rack several more times I came up with 3.745 distance between teeth which is a 1.19207 MOD. so obviously my measurements aren't right.
I'm guessing this has to be a 1MOD rack but I cannot find 1 MOD rack that is 22mm wide by 25mm high.
