Y Axis Drifting during run
Results 1 to 2 of 2
Thread: Y Axis Drifting during run
    Member solzy's Avatar
    Feb 2023
    Default Y Axis Drifting during run
    I have purchased a new Chinese 1325 cnc machine from china, but when running a file on this after a few minutes the Y Axis seems to start drifting and losing its position. At the end of the file if I go to zero point it is completely off on the Y axis. Can anyone give me any suggestions as to why this could be happening?
    CNC router has servo motors, and is running on NcStudio software.
    I am based in UK, West Yorkshire, I would be willing to pay someone to fix this for me as this is quite urgent.
    Thank you
    Jan 2013
    england
    Quote Originally Posted by solzy View Post
    Thank you
    First mark the axis motor coupling to motor shaft and leadscrew, with a marker pen.
    It's possible it's slipping little by little, then try tightening both coupling locking screws. Check the Y axis leadscrew nut also.
    Also, try unplugging and reseating all y axis cables, with power off.
