Prt-e1500w does not reset
Results 1 to 2 of 2
Thread: Prt-e1500w does not reset
    Member woodcnc80's Avatar
    Nov 2022
    Unhappy Prt-e1500w does not reset
    Hello everyone,
    following a reset with D176 command, when I restart the CNC it appears as per the attached picture, do you know a way to reset the board?
    The only thing that does not work is the spindle, otherwise the cnc works fine.
    Thank you very much
    Attached Thumbnails Attached Thumbnails Prt-e1500w does not reset-prt-e1500w-jpg
    Jun 2005
    Default Re: Prt-e1500w does not reset
    The photo shows you have the machine in manual mode. What happens when you press the RUN button? You did not explain exactly what is happening.
    Nov 2022
    Hello, do not turn the spindle, neither in manual mode, nor in pc, nor using pc and controlled by pc, everything worked before. After the D176 command it is as if it went into protection
