Z axis gaining spindle problem motor gets hot. Newbie into cnc - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 55 of 55
Thread: Z axis gaining spindle problem motor gets hot. Newbie into cnc
  1. #41
    Member Chmfhm's Avatar
    Dec 2021
    The video shows the motor turning after it is stopped so it is being driven by the drive, it's getting power from some where to do this.
    Someone told me here in local market that go for servo motor with brakes and servo driver for z axis. Because when you do 3d carving zaxis carves .01mm to 0.001mm and stepper motors are not able to run fast to do this
    What's your opinion
  2. #42
    Jun 2005
    Default Re: Z axis gaining spindle problem motor gets hot. Newbie into cnc
    Chmfhm,
    You will need a dial indicator to check backlash as well as steps per unit. You can pick up one pretty cheap at places like Harbor Freight. As Mactec54 suggested you should first check your steps/unit on the Z axis. If you can tell the Z axis to move exactly one inch does it move that far or is moving more or less. If you command a move of 1" it should move exactly 1"
    Backlash is when you move one inch in one direction and command it to return to the starting point and it does not come all the way back. It is a little more involved but in layman terms this is checking for slop in the ballscrew / nut combination.
  3. #43
    Jun 2005
    What's your opinion
    3D carving a piece of wood does require many moves in all axis. However, the Z axis usually follows the controls of the object being cut, so think of a animal like a horse, so it will follow the contour of the horses body, moving up and down as it sweeps across the work piece. While servos might be able to respond faster, honestly many people do all kinds of 3D carving using stepper motors and they work fine. Focus on the issue with your machine, you can always upgrade to servo motors later after you have much more experience.
  4. #44
    Dec 2021
    Quote Originally Posted by CNCMAN172 View Post
    What's your opinion
    I just check z axis move exactly 25mm up and down from start to finish. So steps of motor is correct.
    Do I need to check backslash too ?
  5. #45
    Jun 2005
    Check the steps/unit first, but they are related. If the steps/unit is wrong it can be adjusted, backlash is harder to fix and usually requires some new mechanical parts if you do not have a double ball nut.
  6. #46
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by Chmfhm View Post
    If the movement went down 25mm and it moved back up 25mm then your backlash would be ok.
    After you had cut the parts where the Z axis had moved down more than it should, when the program finished did it return to the Z axis 0.00 position where it started
    Mactec54
  7. #47
    Jun 2005
    The fact your steps per unit are correct and you have no backlash is good. Another test would be to run another experiment like you did before where Z axis just allows that board to fit. Now move just the X and Y all around the travel and when you finish moving the axis, stop and check the board again. Does the board still fit? It should but this tells us that the X and Y axis are isolated and not causing the issue on Z axis.
    Mactec54 has a good question as well, this tells us if the axis reads 0.00 at the end of the program, then something else was causing it to move.
  8. #48
    Member ZASto's Avatar
    Apr 2005
    Vanuatu
    Could be polarity of Step and Dir signals. If you have it wrong, that is what is happening.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
  9. #49
    Jan 2005
    Quote Originally Posted by ZASto View Post
    He has no problem with Step / Dir signals, motors are moving normally and positioning ok.
    Mactec54
  10. #50
    Apr 2005
    Vanuatu
    @mactec54
    If you have wrong polarity of Step/Dir signals you can and will miss steps, it bite me many years ago when I was greenhorn
  11. #51
    Jan 2005
    @mactec54
    He is not missing Steps
    As I said his axis is moving correctly.
    Mactec54
  12. #52
    Dec 2021
    At last my z axis works now flawlessly and smooth.
    I borrow orignal leadshine dm542 stepper driver from my friend and replace it with cheap junk chinese dm556 stepper
    driver and run machine more then 10 times without grounding and without sheilded wires. It works amazingly without any losing or gaining z axis. Next I will replace x y cheap chinese dm556 stepper driver with original leadshine dm542
    And thx everyone for the help as I am newbie to cnc and you taught me.
  13. #53
    Jan 2005
    Normally the steppers don't need a shielded cable, only the VFD Drive to spindle
    As I said it was an electrical problem, Leadshine make a good stepper drive so now you know what direction to go. you should replace all your drives, make sure you buy a genuine Leadshine drive as there are copies that look just the same, but don't work as well.
    Mactec54
  14. #54
    Dec 2021
    During this I tweak with vfd. Now I have one last problem.
    My vfd rpm doesn't match with mach3. I am sending you pics with vfd manual can you help me on this.
    Attached Thumbnails Attached Thumbnails Z axis gaining spindle problem motor gets hot. Newbie into cnc-20220520_203939-jpg   Z axis gaining spindle problem motor gets hot. Newbie into cnc-20220520_203945-jpg
    Attached Files Attached Files
  15. #55
    Jan 2005
    In Mach3 look at Ports/Pin Spindle setup tab PWM setting it should be 100
    Check the Config Tab in Mach3 under spindle Pulley Ratio 0----24000-----1 you may have to adjust this to get the right output
    Mactec54
