We are stuck in a serious problem.
While machining, Only 1/8'(3.175mm) and 3mm endmills goes higer.
There's no preblem with 4, 6, 10 endmills, V bits.
I've checked g code, there is no problem.
Here's the code and the picture
Picture 1 : Aspire Preview
Picture 2 : Gcode (Z supposed to go -0.2mm below the bottom )
Picture 3 : First path (Z -0.110, suppsed to be -0.2)
Picture 4 : Second Path (Z -0.411, suppsed to be -0.2)
I'm supposing it's the software issue.
Anyone has the same problem?
