What control mode are you trying to use F0.00?My company just recently upgraded to the DZB312009.0L2DK Fuling Inverter as we needed an inverter to reach the 800hz necessary for our GDL60 spindle.
Setup seemed fine and we've input all the correct values in the F1 motor parameters (F1.00-F1.10) but we can't seem to get the inverter to go over 200hz.
It's stuck on H200.0 even when controlled with the keyboard or our handheld terminal. The potentiometer on the inverter keyboard doesn't seem to work at all also, even after setting the SW1 switch to WR.
The only way I've gotten the inverter to successfully output 800hz is when I set F4.02 (Jogging frequency) to 800hz and hold down the jog button. Just to test if it was possible.
The frequency seems to be stuck at 1/4 of what I set it to in the function parameters, as when I set the maximum frequency to 600hz, it would show H150.0.
I feel like it's a parameter that's right under my nose but I can't seem to find or fix it even after factory resetting.
Any help would be greatly appreciated!
